Home > Maintenance & Mods (L322) > MORE SUSPENSION WOES !! 2003 TD6
Blackvogue2012
United Kingdom 2012 Range Rover Vogue TDV8 Santorini Black
having an issue with my suspension......basically i have cleared all the codes that came up with my lr11 icarsoft diagnostic machine but the front of car will not rise more than a few inches... the rear goes up but looks too high, and when i turn car off the front drops again and the rear drops a bit.....lights on the panel are either flashing all at once or on full time ....... i have a high voltage reading (40-50 v) at the front left sensor, im sure it has something to do with it ( the rest are 3/4 volts) would the sensor be knackered or a wiring issue.....new sensor last year !!!
anyone experience this type of fault ??
Post #479399 26th May 2018 10:00am
scotcruz
Scotland 2010 Range Rover HSE TDV8 Zambezi Silver
Sounds like the sensor to me. Have you tried the good sensor from the working side and tried it on where you are getting high voltage? This will eliminate any wiring relating assumptions Current:
- L560 Velar HSE R-Dynamic D180
- Peugeot 508 2011 - 2.2 HDi GT
Past:
- FFRR V 2010 - 3.6 TDV8
- Citroen C4 1.6i Petrol
- Mitsubishi Shogun 3.2 DID
- Peugeot 607 2.2 HDi
- Nissan Primera 1.8 SVE
- Honda Civic 1.6 VTEC
Post #479476 27th May 2018 10:43am
