Home > In Car Electronics (L322) > Bluetooth again |
Nelly Member Since: 02 May 2018 Location: Hampshire Posts: 118 |
Searched through wiki and "search" but couldn't find what I was looking for so...
19th May 2018 9:53pm |
How did you use USB? 2007 range rover vogue, Black with issues
20th May 2018 6:24am |
scotcruz Member Since: 03 May 2017 Location: S C O T L A N D Posts: 391 |
I have a 64GB SanDisk usb in which I have made folders and I simply copy and paste the downloaded music. The USB needs to be FAT32 and it does in the central console.
20th May 2018 6:36am |
Ah OK, didn't even see/ know there was a USB port there, what about Spotify?, is a lead better then? 2007 range rover vogue, Black with issues
20th May 2018 6:56am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35439 |
you haven’t got a usb port on yours, scotcruz has a 2010my which has.. ... - .- -.
20th May 2018 12:58pm |
Ah OK, thanks for clearing that up, so it's Bluetooth then,
20th May 2018 3:12pm |
m@ttsFF Member Since: 12 Dec 2017 Location: Surrey Posts: 333 |
I use one of these through the aux port - no track changing from the wheel or touchscreen. I connect to the stock BT for calls and music only to the receiver
20th May 2018 6:32pm |
That's the one I was looking at, you can go back an forth for tracks on the little gizmo, right?
20th May 2018 7:06pm |
Sorry folks.. I thought USB was standard.. Current:
20th May 2018 7:07pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6738 |
Get an Ezi-dab. That has iPhone and ipad input via a cable. If you have RSE, you can select AUX on your audio screen and use the source selection on the Ezi-dab controller.
20th May 2018 7:54pm |
OK that's an interesting bit of kit, and a possibility ,
20th May 2018 8:13pm |
Yes Neil, a few of us have them.
20th May 2018 11:49pm |
Had a look,done some investigateions , and ordered one
21st May 2018 7:10pm |
