Home > Maintenance & Mods (L322) > Passenger front door not opening
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
Front passenger side door doesnt open with the outside handle, but still works from inside the car (if you lean acros from drivers seat and wind yourself on the armrests Crying or Very sad )
Is this a common fault guys? I'm sure we had a cable replaced in it 2 or 3 years ago (my memory is rubbish), could it of gone again already??? It only gets opened a few times a month, so surely it cant be that??
EDIT: Having searched my previous posts, it did indeed go 2 and a bit years ago, could it of gone again already? Its hardly used Crying or Very sad
Post #467670 7th Feb 2018 5:32pm
outer cable has snapped or its end has come out of the door lock mechanism .. ... - .- -.
Post #467674 7th Feb 2018 6:08pm
TDSIX
United Kingdom 2011 Range Rover Vogue TDV8 Nara Bronze
This happened to me this morning - driver door would not open from outside or inside. I was all ready to buy a replacement cable, but after leaving the car parked in the sun for a couple of hours, its fixed itself - it was frozen! was -5 this morning... hopefully you are just frozen out too! 2010 FF 4.4 TDV8 Vogue - Gone
2007 FF VSE 3.6 TDV8 - Gone
2011 RRS HSE 3.0 TDV6- Gone
2003 FF TD6 Vogue - Gone
2006 FF TD6 - Gone
2007 FF 3.6 VSE - For sale
2011 FF 4.4 TDV8 - Current
Post #467676 7th Feb 2018 6:24pm
John w
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
I Had similar on Monday.
The handle was frozen, and the door opened fine when I pulled the handle but wouldn't close at the cable/handle/mechanism must have been stuck in the pulled state.
After 3 or 4 attempts to close the door it latched again correctly. Too many toys, not enough time
2011 4.4 TDV8 AB Black
Post #467677 7th Feb 2018 6:36pm
mrblonde
Just tried it again guys, and sadly it still wont open. Hoping its come out the mechanism, as it'll be the 2nd cable in that door in as many years Big Cry
Post #467830 9th Feb 2018 10:15am
Bagus
United Kingdom 2016 Range Rover Autobiography 5.0 SC V8 Loire Blue
Did you end up fixing this and was it a pain to do?
I`ve just encountered the same problem with my front passenger door. It opened fine this morning and now nothing. Big Cry
Post #478774 18th May 2018 11:44am
Dolphinboy
Vagus it is an hour to do. Lots of info on here and on YouTube. Search is your friend Thumbs Up
Post #478824 18th May 2018 7:39pm
