I agree, although many people say that less than 1amp is acceptable, but they say this with a slight hesitation. When I say people I mean the 2 RAC guys, Land Rover main dealer (although body shop) and also a friend who has run his own motor engineers for 60 years. I agree ideally it should be down to 0.1ma-0.4ma but it doesn't seem possible with all the tech on the car. Land Rover themselves told me that the L322 is renowned for this, and even many owners of 405s are complaining of flat batteries after a few days.
Before finding the cover for the diagnostic port was causing a 2 amp drain, one thing I did when testing, was leave the car for an hour and check - the drain remained at 3amps regardless.
When I found the issue with the diagnostic port, I didn't bother waiting to see how much the drain reduced from 0.9a after an hour or so as I had many other things i needed to get on with. But your reply is a timely reminder that I need to do more and see what the drain is after an hour, and see if I can find the root cause of the 2amp drain from the diagnostic port. I was hoping my post which is asking "if anyone else had seen the drain from the diagnostic port, or had any ideas why it might be the case" would provide a hint or two for me to chase down, but alas no responses yet.
Mark
