Home > Technical (L322) > Reduced power sterring and dash warning lights.
lounge_on_wheels
Australia 2003 Range Rover HSE Td6 Zambezi Silver
I was traveling along like a happy camper in the rain when " boing" the chime went sounded and the ABS and Brake light came on, the display showed ''air suspension inactive''
The power steering also took more effort.
I got home and ran my iidtool over it and got an error about the wiper motor / rain sensor fault or something like that. plus other faults. I cleared them and re enabled the EAS and turning steering wheel from lock to lock fixed the heavy steering.
I assume water has got into a connection somewhere. I had an odd fault over the years when it was raining causing a glitch somewhere but it hasn't played up again until now.
Post #478437 15th May 2018 5:22am
verydisco
Could it be signs of the Alternator starting to go?
what is the voltage when you have the engine running on standstill? l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #478456 15th May 2018 9:07am
lounge_on_wheels
Battery voltage is 14,1 volts at idle
Post #478475 15th May 2018 12:57pm
abs or height sensor? ... - .- -.
Post #478476 15th May 2018 1:16pm
lounge_on_wheels
Today the brakes locked due to ABS fault and speedo stopped working. Fault codes relate to "rear left wheel speed sensor open circuit".
I am replacing the sensor with a genuine Land Rover Part as the aftermarket one fitted 12 months ago seems no good.
Post #478544 16th May 2018 6:18am
lounge_on_wheels
Fitted a new genuine ABS sensor to the Rear left wheel and all is back to normal. Gotta love BMWs engineering ( NOT) thet one components is interconnected through all systems
Post #478863 19th May 2018 7:25am
