Home > Maintenance & Mods (L322) > Fronr suspension arms
Geo2toy
United Kingdom 2011 Range Rover Vogue SE TDV8 Java Black
Hi all
so My 2010 FF has a knock on the front and it sounds like its an arm so I want to replace upper and lower arms as well as ball joints and the anti roll bar links.
Done this a couple of years ago with my last FF and they were an aftermarket brand and were absolute Rubbish and now been told Delphi are now rubbish as well.
So has anyone got a recommended brand or a supplier of good quality aftermarket arms etc.
Help much appreciated.
Thanks Geo Thumbs Up
Post #478405 14th May 2018 9:30pm
holidaychicken
Try the Britcar site for alternatives , their PR2 is OEM type I believe but I would have thought Delphi would be ok. Not sure if Febi have started doing suspension parts. Moog are ok I think but I generally try and get Delphi
Post #478431 15th May 2018 12:38am
Strider
England 2007 Range Rover Vogue SE 4.2 SC V8 Zermatt Silver
+1 For Delphi Thumbs Up ,
Had them fitted for front end knocking, cured it, with no problems.
Post #478477 15th May 2018 2:18pm
thrillcat
United States 2012 Range Rover HSE 5.0 V8 Santorini Black
I used Lemforder when I refreshed my front suspension earlier this year, except for the sway bar links, those are Delphi. Was happy with the quality of all.
Lemforder was a habit from my X5 4.8is days....Always high quality. 2012 L322 5.0l NA
Santorini Black / Sand
Post #478596 16th May 2018 5:57pm
Lemforder or Delphi, both OK.
The drop links are Lemforder from the factory, last time I did arms I used Delphi for the arms and lemforder ball joints and arb links.
If you can get Lemforder arms then that would be the way to go. There is nothing that can't be fixed with a hammer😜😜
Post #478615 16th May 2018 8:24pm
