![]() | Home > Technical (L322) > Aircon compressor voltage |
alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349 ![]() ![]() ![]() |
Could someone guide me to the whereabouts of the aircon compressor relay , Aircon not working 12v feed activates the clutch but only 9v feed , I have read a lot about this and cant get to the bottom of my problem . I checked out the switch/sensor on the high pressure line and I get two pins showing 5v and Zero on Brwn/Blck wire Taking the plug off the sensor starts the high speed fan but if I link the Brwn/blck to Blck/gry the fan stops . The only other wire is Grn/yellow which hods 5.0v So three wires in total .(trinary switch perhaps)?
That’s great , .... progress , I’ll rig up some test for that, what is throwing me is the Gap tool is telling me I have 5.33 bar ehich I don’t believe or it the sensor that’s faulty killing the the feed to the compressor, in any case if the compressor is idle the the values in either line should be equalised at the moment due to the fact that it’s not working . Post later . Cheers pat
What I meant in the last reply was , As you say the sensor seems to control the compressor to go off and and on. Was thinking if I could hot wire this.Cheers |
Certainly did , I managed to insert a pin through through the back of the cable plug to the sensor and while off it read 5.0v and on it reads 0.44v , so theoretically the system is low in pressure going by that. I also coupled up the compressor briefly with 12v while monitoring the GAP Tool and the pressure raised from 5.33 to 6.100- .330 so Im also thinking the pressure sensor maybe at fault as well . I have ordered some replacement gas although Im reluctant to waste a recharge! |
cheezels Member Since: 23 Apr 2016 Location: Sunshine Coast Posts: 279 ![]() ![]() ![]() |
Do you have access to normal gauges to compare the IID tool reading with.
Yes I might do that to compare, let you know. |
Ok put my manifold gauges on and there is no pressure , so to that end a good recharge shoud do it ......with some leak stop! |
kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 225 ![]() ![]() ![]() |
Stop leak or a new condenser maybe ? |
