Home > Maintenance & Mods (L322) > Key turns barrel - does doesn't unlock \ lock
Cryptic
2002 Range Rover Vogue 4.4 V8 Java Black
Hi,
2nd help shout today - as I have the door apart, it's time to sort out why when turning the key in the lock it does nothing - central locking works fine.
I did see a video about this some time ago - but blowed if I can find it again.
Any pointers as to what's wrong \ location of the video?
Thanks again
Post #478148 12th May 2018 2:18pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
Can't help but hopefully someone will reply , did you try the search function ? 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #478154 12th May 2018 2:57pm
Cryptic
Yeah - spent ages searching - will persevere
Post #478157 12th May 2018 3:21pm
dolph34
 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #478158 12th May 2018 3:34pm
dolph34
Any use ? 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #478159 12th May 2018 3:34pm
Cryptic
Yes, I've just had a watch of that. Also found on here http://www.fullfatrr.com/forum/post309864.html
"finally your driver's door lock extension bar has probably slipped out! (i presume when you turn the key there is NO resistance? Like your turning fresh air) So, remove door lock (hidden torx bolt behind a rubber grommet inside your door behind the lock) slide the lock out of the door and see if the extension bar has fallen down? You will see the end is much like a X head screwdriver and when you gently push the lock back in, this must locate into a slot in the mechanism and "
Combined, I reckon I'm in with a fighting chane Very Happy Very Happy Very Happy
Thank you folks
Post #478160 12th May 2018 3:41pm
dolph34
Thumbs Up 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #478165 12th May 2018 3:54pm
