Home > Maintenance & Mods (L322) > Idiots have been at work |
Nelly Member Since: 02 May 2018 Location: Hampshire Posts: 118 |
12th May 2018 11:10am |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 491 |
Looks like an after market camera has been fitted. On one of the many replacement camera threads there is a pic of what wires go to what. You change the new camera wires and wire it into the orginal wiring and one lead connects to the coax Current 2007 TDV8 Vogue Buckingham Blue |
12th May 2018 2:45pm |
You could be right, I did re solder the connections but still don't work, so gonna get a cheap one off ebay, it an NSTC (or whatever it is) one I need,? |
12th May 2018 5:47pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7941 |
You need to fill your car details in - on your profile - there are different cameras across the years |
12th May 2018 6:02pm |
Done basically 2007 FF Vogue 2007 range rover vogue, Black with issues
12th May 2018 6:20pm |
Does this thread help ?
12th May 2018 6:41pm |
Thanks for the link mate, those are not available now,
13th May 2018 6:47am |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 |
Dont get one with built in Leds.
13th May 2018 10:03am |
Ah OK, thanks for the heads up,
13th May 2018 12:08pm |
Try and get one that is NTSC only otherwise picture issues arise. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
13th May 2018 12:27pm |
Thought that one was, will check 2007 range rover vogue, Black with issues
13th May 2018 12:28pm |
It says pal/ntsc 2007 range rover vogue, Black with issues
13th May 2018 12:29pm |
NTSC only, not both. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
13th May 2018 4:02pm |
Sorry my mistake
13th May 2018 5:01pm |
