Home > General > MPG gone mad !
David
Spain 2007 Range Rover Vogue SE TDV8 Zermatt Silver
MPG gone mad !
Since having the new tyres fitted and full service my MPG has gone mad. I was getting 29-31 over a week, mostly M WAY driving @ 100kms on cruse controll.
Now its showing for the month 26.5 and when i set off for work this morning the week was 26.4. I watched it on the M Way and the week fig was rising all the was to 28 by the time i got to work, but the Monthly fig had DROPPED to 26.1 ? How can this be if the other fig was riseing ? 2007 TDV8 Vogue SE
Post #47780 27th Jan 2011 10:01am
dan_uk_1984
Wrong oil? Poor Quality air filter?
Post #47786 27th Jan 2011 10:47am
David
Hope not was done at a main dealer ! 2007 TDV8 Vogue SE
Post #47787 27th Jan 2011 10:54am
if the battery was dis-connected then maybe the ecu has reset it self and is giving you a different reading..leave it for a couple of weeks and it might show the same mpg then... ... - .- -.
Post #47789 27th Jan 2011 10:59am
David
Just thorght it strange that one was going up and the other down ! 2007 TDV8 Vogue SE
Post #47794 27th Jan 2011 11:42am
the figure is an average , a combination of the lowest and highest mpg. ... - .- -.
Post #47795 27th Jan 2011 11:44am
phillh
United Kingdom 2002 Range Rover Vogue 4.4 V8 Giverny Green
Dont worry about what the computer says its doing, find out how much fuel its actually using by brimming the tank.
ph
Post #48010 28th Jan 2011 7:21pm
phillh
ph
Post #48011 28th Jan 2011 7:22pm
you'll find the FFRR mpg readout is very accurate..i did a long run and did a rim to rim and it was .2 of a mpg out with the readout... ... - .- -.
Post #48016 28th Jan 2011 8:17pm
A1GSS
Re: MPG gone mad !
David wrote:
... getting 29-31 over a week,
Really...? That's pretty good. Anyone else claim similar figs? Graham
____
Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Gone: 20MY Jaguar iPace HSE, Silicon Silver
Gone: 17MY RR Evoque SE Tech, Loire Blue
Gone: 08MY Discovery 3 XS, Stornoway Grey
Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey
Post #48041 28th Jan 2011 9:42pm
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
Well I don't know about the going up v down, but you mention the tyres have been changed.. and I've been paying attention to recent threads to so I know the answer...
Thrashing the ass off it in sand / mud with low pressure in the tyres has caused a HUGE dip in consumption Laughing And going back to try it again... well Rolling with laughter
Then after deflating make sure they are back up to full pressure and aren#t leaking around the rims. I's easy to dislodge rubber from a tyre when the pressures are low so maybe one isn't seated properly.
All the above are assumptions that low pressure may still be evident on one or more tyre. Correct pressures should be displayed on the drivers B pillar. 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #48048 28th Jan 2011 10:28pm
