Home > Technical (L322) > MY10 air suspension fault Help please!
BJG
Sweden
Hello guys,
Have a MY10 that im very much in love with.
Two days ago i got a Suspension fault notice in the dash.
Morning after it was down on access mode/ bump stops. Started the car and it quickly raised to normal height.
I drove it for 300km and it felt normal but the warning stayed on.
It still raises quickly to all positions.
Read the codes today with an icarsoft and it says: C1A04 Front right height sensor.
In the dash when i press 4x4 info there is a red mark under front right tyre.
Looking at livestream i have 4.90 volt at all four sensors.
In offroad-mode:
Front left corner height 52mm
Front right corner height 52 mm
Rear left corner height 57mm
Rear right corner height 34mm
-If the icarsoft is right i think i need a new front right sensor - correct?
-Why is it lowest at the rear right?
I looked at the sensor front right and it says: AH42-3C097-AB
Looking at ebay it seems to be for a RRS? It was a 3 pin connector. Noticed that there is both 3pin and 6pin connectors available.
Post #477937 10th May 2018 12:55pm
GraemeS
6-pin sensors are for vehicles fitted with CVDs (adaptive dynamics).
Post #477966 10th May 2018 8:31pm
