Home > Technical (L322) > Brakes groaning
cheezels
Australia 2007 Range Rover Vogue TDV8 Java Black
That’s correct.
Squealing is a different animal to cage 2007 3.6 TDV8
Post #477497 4th May 2018 2:54am
Tight777
"Replaced the dampers on the top of the struts - joy! "
The Damper your talking about looks like just a heavy lump thats not going to fail, so is there a bush or something built in that fails?
Post #477725 8th May 2018 9:44am
Harlin
England 2006 Range Rover Supercharged 4.2 SC V8 Java Black
still trying to get this thread to dan but not sure how too
Post #477846 9th May 2018 5:47pm
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
Just copy the link to this thread and start a new thread in the Duckworths channel referencing it? Or send him a PM with the link? 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #477847 9th May 2018 6:16pm
Harlin
sounds easy but you are talking to a halfwit tehcnophobe Surprised
Post #477850 9th May 2018 6:41pm
MikeO
Here's the link you need:
http://www.fullfatrr.com/forum/viewtopic.p...847#477847
PM that link to Dan. 2016 Skoda Octavia VRS Estate
Post #477861 9th May 2018 7:38pm
cheezels
Keep in mind that I fitted the new dampers after fitting new struts.
I couldn’t get the dampers off the old struts, so ordered new ones in the end.
The dampers are loctited on, so very difficult to remove (particularly with the strut on the vehicle). 2007 3.6 TDV8
Post #477890 10th May 2018 12:34am
Harlin
thanks for your help mate
Post #477929 10th May 2018 12:23pm
nino_nino
Post #477938 10th May 2018 2:17pm
Arbuckle
United Kingdom 2012 Range Rover Westminster 4.4 V8 Fuji White
The six pot calipers on my 4.4 TDV8 seem prone to this.
I think the 'stick-slip' vibration at very low speed is caused by differing coefficients of friction values for static and dynamic conditions. Theory is great but finding a practical resolution can be a pita. Usually a mass is added to 'oppose the forces' at the vibration frequency, or an elastomeric component introduced to reduce the transmission of said vibration.
The 'simplest' solution is to change the composition of the friction material. Interesting that JLR have not taken that path. Forty years of progress. 1972-2012
Post #499650 25th Dec 2018 6:44pm
TJH1985
If you look up the spec of the lock tite LR use, it details how to release it. After spending several hours trying to remove one I looked up the lock tite and it needed heat to release, heated it to the temperature stated and they literally can just be screwed off by hand (with a glove obviously). If you use a infrared thermometer you can check no heat is dissipateing into the damper.
They are just blocks of Ali, not sure how one could fail? I always assumed they were to be replaced because without heat they are a nightmare to remove
Post #499653 25th Dec 2018 7:15pm
How much heat?
Hair Dryer / Paint Stripper Gun / Blowtorch (handheld) / Welding Torch ? .
Post #499658 25th Dec 2018 7:55pm
TJH1985
I think it’s Loctite 648, LR calls for STC5055 which cross references to Loctite 648 and can be seen in most of the pictures selling STC5055
The data sheet is here: https://tdsna.henkel.com/NA/UT/HNAUTTDS.ns...648-EN.pdf
1) Remove with standard hand tools.
2) If needed, apply localized heat to the assembly to approximately 250 °C. Disassemble while hot.
3) If this temperature is not possible, heat as much as possible and use mechanical aids.
I used a good hot air gun with a small directional nozzle, once it got over 200 I just screwed it off with some welders gloves. No idea if it would have gone earlier as I didn’t try it. This was with the strut off the car and on the bench, nothing else really got that warm.
Wish I had known originally, had some rather large bars and industrial impact guns on it and it didn’t even look like it would budge - it’s insanely great stuff!
If I remember right they are fairly expensive to buy Neutral especially when you are already forking out on OEM parts, I had it in bits as one of our bags failed.
Post #499663 25th Dec 2018 9:48pm
