No sat nav or tmc signal - solved | |
I think I might have nearly got to the bottom of the issues that arose after a flat battery.
However, whilst trying to chase a 3 amp drain I pulled all fuses one by one. At some point shortly after this I noticed that I have lost connectivity to satellites for nav. Now, I understand it can take a while to re-establish the connections, but this is not as simple as that. The car has been run for a few hours at least, and still no satellites or TMC as yet.
I checked connections at that back left of the car into the disk unit and they all seem ok. I have checked the fuses that are related (according to manual) and they are all ok.
Any ideas? I use the sat nav a lot and having spent so much time getting things right on this car, just as I get there ten more things go wrong and I just cannot live with anything that doesnt work as it should. I need to fix this despite the rather questionable abilities of the nav unit.
About 3 weeks ago, a LR body shop did respray my roof, disconnected the shark fin aerial and removed the windscreen to do the work. I have since used the sat nav for thousands of miles across Europe with no issues until Monday this week when I had my second flat battery in 7 days..
Thanks
Mark .
