Home > In Car Electronics (L322) > sat-nav co-ordinates
westminster 62
United Kingdom 2012 Range Rover Westminster TDV8 Santorini Black
Hi, I tried typing an address on my sat-nav using the co-ordinates feature, started typing in the latitude numbers but before i could type all the numbers it went onto longitude, it won't let me type in the full set of numbers.
Has anybody had the same problem.
My car is a 2012 4.4TDV8 Westminster
Post #477432 3rd May 2018 1:35pm
not had to do that type of input ....can you put the postcode in and then use the display map function to fine tune the location...
...what does it say in the user manual.. ... - .- -.
Post #477435 3rd May 2018 1:46pm
Baltic Blue
I booked a hotel in France last year and they gave the co-ordinates rather than a post code.
I remember struggling to put it in , but seem to remember that the shorter version ie leaving off the last digit, on both latitude and longitude took me to within visual contact .
Sorry can’t be more specific because that is the only time I have used the facility.
Post #477440 3rd May 2018 3:07pm
Weegie
Try changing the country to France. John
GAP iiD BT
Post #477445 3rd May 2018 3:34pm
op doesn’t say that the co-ordinates are in france john.. ... - .- -.
Post #477446 3rd May 2018 3:36pm
Weegie
My error, Stan Thumbs Up John
GAP iiD BT
Post #477447 3rd May 2018 3:45pm
Wink ... - .- -.
Post #477455 3rd May 2018 4:57pm
Stormin
2003 Range Rover HSE Td6 Epsom Green
I visit southern Ireland with work and find that my garmin, in my works vehicle doesn't accept all the numbers. but luckily it has taken me to where I need to be Three things in a blokes life his dog,his car and a Cornish pasty,nothing else matters.
2010 Range Rover Vogue SE Santorini Black, Arabica Aniline seats
Previous cars
1973 Mini 1000
1971 Hillman Avenger
1975 Chrysler Sunbeam
1981 Ford Cortina
1985 Volvo 340
1989 VW Golf
1989 Volvo 240
1991 Volvo 240
1991 Jaguar Soveriegn
1996 BMW 730
2003 Honda CRV
1999 Jaguar Soveriegn
2003 Range Rover HSE Epson Green with Sand trim.
Post #477458 3rd May 2018 5:22pm
IanV8
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
The RR sat nav works in degrees , minutes and seconds not the more common decimal degrees.
There are on line converters but I made an excel sheet to convert them as I use them all the time for Caravan sites, last trip I had about 20 listed.
It would be nice to be able to load them from a memory stick after planning on the home computer but no option.
Ian
Post #477503 4th May 2018 7:22am
westminster 62
Have tried it with fewer digits and it does work, but it's not very accurate, i typed in the co-ordinates for dover and it was telling me my destination was about 2 miles into the english channel, think i will stick to using post codes.
Post #477507 4th May 2018 7:43am
IanV8
It is very accurate but as I said above you have to convert it to degrees minutes and seconds.
If you wanted to put 53.50 in it would be 53 degrees and 30 minutes.
I use it all the time and will take me to the gate of the planned campsite.
Try converting your coordinates on line and try again.
Ian
Post #477570 5th May 2018 8:23am
