Home > Technical (L322) > L322 TDV8 2006 POWER STEERING LEAK
PUPPYDOGS
United Kingdom 2006 Range Rover Vogue TDV8 Java Black
Just noitced i have a power steering leak,i filled the bottle to max and on start up and just empties,took the bottom engine cowl off and one of the two power steering pipes is dripping but i cant see where is coming from.
Help please !
Post #477114 29th Apr 2018 5:28pm
download the workshop manual and see if you can trace the pipe work.. ... - .- -.
Post #477117 29th Apr 2018 5:33pm
Motobox
United Kingdom 2004 Range Rover Vogue Td6 Galway Green
Maybe not related. The reservoir bottles get really brittle and crack on the underside.
Post #477257 1st May 2018 9:30am
Mikey
Cooler pipes corrode
Rack input seals leak
One relatively cheap, the other not so...
Post #477261 1st May 2018 10:12am
