Home > Technical (L322) > Oil in intake system causing catastrophic engine failure |
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 |
I still want to know who all the silenced people are Alex
1st May 2018 7:33am |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3753 |
I’ve had 16 Range Rovers, several being the 4.4 TDV8, no engine issues whatsoever with the 4.4 TDV8, and not aware of any engine failures of others due to over running on its own oil.
1st May 2018 8:42am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3545 |
Crystal never came back on this one....
29th Sep 2018 5:09pm |
AngelsBoy Member Since: 31 Jul 2020 Location: Prague Posts: 20 |
Hi Graemes, it seems that k leaks in the secondary turbo precisely because of what you write? Can it have a very negative result in the final? Or should I replace the drain pipe? now I've wiped it and I'll see if it leaks again ... I suspect there's also oil from letting go of the Turbine shut-off valve (on the secondary turbo-there's now a new-this valve). I have L405 2013 but VIN 103753 and I read here that it is a pain for my model too ?! |
31st Jul 2020 10:51am |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
With regards to the turbo drain mod, IMHO it is entirely possible to get to diesel runaway IF your engine is affected by oil in the secondary turbo. When the 2nd turbo hasnt been used for a while the oil builds up, gets dumped into the intercooler and some of it get burned. At some point when the intercooler has sufficient oil in it and just enough airflow to carry it to the cylinders away it will go. There will be a massive increase in airflow followed by plenty of oil for fuel.
31st Jul 2020 1:19pm |
31st Jul 2020 1:33pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2523 |
Oil leaking externally from the secondary turbo might or might not be an indication of oil pooling whereas thick smoke from the exhaust on heavy throttle after sustained light throttle use is the indication that oil has accumulated. If the smoke is occurring then either change driving habits to regularly cause the secondary turbo to be used to prevent significant oil accumulation or have the modified drain fitted.
31st Jul 2020 10:13pm |
Yes I read about your secure EGR device
1st Aug 2020 7:47am |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3836 |
I gotta say I'm with Rambles on this, there are lots of posts on this forum that make me a bit paranoid about what could go wrong. I change down on the motorway regularly expecting to see clouds of smoke in my mirrors, nothing, so I just keep on trucking and mines a 2013, so one of the first.
1st Aug 2020 4:48pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7829 |
That’s ok then.....
1st Aug 2020 4:56pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8655 |
Does the SDV8 not have the modified drain factory fitted? There is nothing that can't be fixed with a hammer😜😜
1st Aug 2020 5:18pm |
unfortunately they allegedly do not have the first models (L405). And I'm also quite stressed after a week of reading here on the forum L405 2013 Vogue 4.4 SDV8 339.000km/211.000miles |
1st Aug 2020 6:17pm |
The factory-fitted dual drain was introduced somewhere in the MY14 model run. The factory-fitted drain is slightly different to the retro-fitted drain in its sump attachment and the pipes themselves. |
1st Aug 2020 8:45pm |
