Home > Technical (L322) > Rear wiper and washer stopped working
smiler289
Hi. I have an 02 plate l322 and the rear wiper stopped working last week. The arm stopped halfway across the window. Washer does not work either.
I've tested to see if there's power getting to the motor and there is on both plugs, however I don't know which wire is connected to the stalk switch to check that is working. On the smaller of the two wire plugs I get power from the larger wire but nothing from any of the other wires.
I have had to replace one of these motors on our pre ious l322 due to the washer fluid leaking but this appears to be a different problem, saying that this motor has been leaking too.
Post #477128 29th Apr 2018 6:30pm
have a look in the wiki Thumbs Up ... - .- -.
Post #477141 29th Apr 2018 7:56pm
smiler289
Hi. Thanks but I did, I may have missed something but from what I have read nothing helped me with my problem.
Post #477142 29th Apr 2018 7:58pm
markcartlidge
I had this problem myselflast year. It started working after about 6 weeks. The 2nd time it stopped I gave it a push and it started again. It has now stopped working again. I think it may be worn electrical contacts but I have had chance to investigate.
Post #477163 30th Apr 2018 6:48am
smiler289
Problem solved. Motor was toast. I replaced it with a new unit and it worked straight away. Unfortunately the price of the motors has gone up alot. £217.
The water squirty nozzle doesn't stay clicked down on the nozzle though which is annoying.
Post #477404 3rd May 2018 8:04am
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
http://www.fullfatrr.com/forum/topic884.html 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #477405 3rd May 2018 8:35am
