![]() | Home > General > 2010-2012 4.4 TDV8 L322 advice needed please! |
160dmb Member Since: 16 Dec 2012 Location: Hertfordshire Posts: 455 ![]() ![]() ![]() |
I am assuming you know that the dial versus the stick gear lever indicates an 8 speed gearbox and the 4.4TDV8 over the 3.6. Just for clarity only the diesels get the rotary dial and 8 speed box, the petrol L322 remained with the same gearbox.
mike2013 Member Since: 11 Feb 2013 Location: UK Posts: 27 ![]() ![]() |
Dear 160dmb
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
The best advice is to buy on condition and history not spec, mechanically they are all the same and really apart from some gadgets which are rarely used and cooled seats there is little difference is the models. I do agree on the missing knobs on the vogue however if it were a choice between an excellent Vogue and a slightly less excellent vse then the vogue would win.
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
Morning Mike
Many thanks also northernmonkey and rjff (and that’s a great review on the Honest John site - thanks). |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
As far as trim and toy goes, this is an approximate guide to which toys were fitted to which model:
Thank you. That would be much appreciated.
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3757 ![]() ![]() |
The Westminster is the later run out model, it replaced the Vogue and Vogue SE, but the VSE had far nicer seats. I Agree with buying the best condition you can find, but I would go for a VSE or Autobiography if given the choice over a Vogue or Westminster. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
Thank you Vogue.
Fwiw, my last L322 RR was a 2011 VSE 4.4 TDV8, bought new, covered 69k faultless miles, absolutely zero issues, I have owned Range Rovers and Land Rovers solely since 1973 and so far it has been the best out of all of them. Serviced on time and driven like a car should be has probably helped. If you can find a good one it is the absolute pinnacle of motoring - I have absolutely no desire for any other make of car. I would take the RR every day over an Aston or a Bentley. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
Rocketuk Member Since: 10 Apr 2018 Location: Redditch Posts: 25 ![]() ![]() ![]() |
Hi a few months ago I was thinking the same
I think the 22 inch look the best!! |
Hi again yes the wheels look great and the car had lived all its life in and around central London so I'm sure no problem.
