Home > Maintenance & Mods (L322) > Squeaking brakes
Rocketuk
Squeaking brakes
Hi everyone , two weeks into owning my 2011 L332 and found a annoying squeak as the car comes to a stop under breaking .
Its only the last part of stopping it happens so i dont think its worn pads?
It had a service and mot less than 1000 miles ago.
Any ideas
Thanks
Post #476585 23rd Apr 2018 7:27pm
the brembos are pain for squealing, usually the pads need a bit of brake grease on them to stop the squeal. Mine have just started to squeal again but thats because the pads are on their last legs.
If you are handy with the spanners whipping the pads out of the brembos is not too difficult. Little bit of grease on the sides of the pads will help. There is nothing that can't be fixed with a hammer😜😜
Post #476588 23rd Apr 2018 7:36pm
gettingold
I had the same as you Rocketuk and it became embarrassing, it actually was the front pads. Changed pads = noise gone. Unless you did the service yourself have a look at the pads, don't assume somebody checked them Thumbs Up
Steve.
Post #476620 24th Apr 2018 6:53am
Rocketuk
Thanks for the advice
Will get the wheels off over the weekend and have a look
Post #476633 24th Apr 2018 10:41am
gettingold
depending on what alloys you have on you may be able to see through the spoke with a decent light, so again may save any graft unless you have to.
Steve.
Post #476638 24th Apr 2018 12:00pm
muppet
United Kingdom 2012 Range Rover Westminster 4.4 V8 Barolo Black
I had the same issue and all the neighbours would know when I had just pulled up. It was in the dealers a couple of times and eventually they solved it by applying some anti-squeaking solution on the pads / discs that apparently they use for Land Rovers in the USA and it has just been introduced in the UK. That's what they told me anyway.... I need more help than most...sorry !!
Post #476647 24th Apr 2018 1:55pm
Rocketuk
Thanks again for the replys
Think it's a grease issue as two wet days with no squeaking
Will let you know what I find out
Post #476851 26th Apr 2018 7:47pm
