Home > Technical (L322) > Driver door
Tang37
United Kingdom 2005 Range Rover Autobiography 4.4 V8 Java Black
Driver door
Hello. I had my driver door lock replaced on my 2005 L322 the other month and now when it freezes the door won’t open or if it does open it will not close. I have to get the car hot for a long time before it will close or open. But now the warm weather has come it opens and closes perfect. Has anyone else’s had the same problem is there any seals that might need changing inside the door. Thanks.
Post #476610 23rd Apr 2018 10:35pm
have the same problem on mine, I think that some moisture gets into the lock and freezes.
I took out the small rubber bung near the lock mechanism and applied liberal amount of spray lube. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #476611 23rd Apr 2018 10:38pm
Tang37
Thank you for that
Post #476612 23rd Apr 2018 10:44pm
