Home > Maintenance & Mods (L322) > Bleeding Jack
supershuttle
Bleeding Jack
I have a Merc Sprinter Jack but its running out of puff before it gets to a sufficient height to remove wheels - it was OK. I've ordered some Hydraulic Jack Oil to bleed it and the top it up but I just realised I don't know how to do it - can anyone help? Geoff
Post #476348 20th Apr 2018 5:58pm
Giantlandyman
United Kingdom 2012 Range Rover Autobiography TDV8 Santorini Black
There's several clips on YouTube for bottle jacks in general. I don't know if any of them will be relevant.
Post #476374 20th Apr 2018 9:11pm
supershuttle
Cheers mate, I had a look you are right. If it confirms to "the norm" I should be OK, I've ordered the Hydraulic Oil so will give it a try next week. Geoff
Post #476420 21st Apr 2018 3:44pm
I broke mine...... don’t ask.
It went in the skip, got to order another. There is nothing that can't be fixed with a hammer😜😜
Post #476429 21st Apr 2018 6:45pm
Baltic Blue
Broke it ?.
I bet you had a Tonka truck as a kid Rolling with laughter Rolling with laughter
Post #476433 21st Apr 2018 7:10pm
I broke mine too Embarassed put a kink in it and it leaked fluid Thumbs Up
Second trailer puncture of the trip, so I jacked up my trailer (still attached to the car) removed the wheel and got distracted, before driving off to get a replacement tyre - so yes - the trailer was still attached - fortunately twin axle, so disaster avoided, but it cost me a jack Embarassed
Post #476435 21st Apr 2018 7:23pm
I removed the top cradle to fit a jacking adaptor and accidentally pushed the piston back too far, after that I couldn’t get it back together satisfactorily so it wen tin the bin...... new one on its way from the bay. There is nothing that can't be fixed with a hammer😜😜
Post #476463 22nd Apr 2018 11:35am
New jack has arrived. all shiny and new.
just got to fit the adaptor to the top without breaking it now..... There is nothing that can't be fixed with a hammer😜😜
Post #476688 24th Apr 2018 9:16pm
Vogue
Why on earth are you jacking up a twin axle trailer ???? Far far simpler, quicker and safer
You can even make one out of a block of wood or just drive up a car ramp or even a kerb Thumbs Up 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #476692 24th Apr 2018 10:01pm
Now that is a good idea!! There is nothing that can't be fixed with a hammer😜😜
Post #476735 25th Apr 2018 6:44pm
supershuttle
Easy job but it still leaks fluid, I needed the jack to rotate the tyres because the front nearside had taken a bit of a hammering - roundabouts I think, job now done. However I still have the issue of tyre pressures I’ve got 22” wheels on an L322 I went with 33 front and 36 rear as suggested for L405, seems OK anyone have a different setup.? Geoff
Post #476796 26th Apr 2018 9:20am
use the spare when rotating the wheels.. ... - .- -.
Post #476798 26th Apr 2018 9:24am
supershuttle
I've only got 4, spare doesn't match Big Cry Geoff
Post #476800 26th Apr 2018 10:03am
I saw one of those, but seemed quite expensive and bulky for something I thought I didn't really need Confused
Whenever my trailer isn't in use, I jack it up and replace all 4 wheels with stands - so I'm kind of programmed to just jack it up.
Mine still has the 'ears' on it, so relatively safe to jack a trailer axle as long as you don't drive off with it jacked up Embarassed
Post #476804 26th Apr 2018 10:23am
spare doesnt have to match Geoff...
for instance, take near side front off, replace temporally with spare then stick nsf where ever you need it.. ... - .- -.
Post #476809 26th Apr 2018 11:27am
