Home > Technical (L322) > Radio Interference when Heated Rear Screen Selected????
paultuk
Hi guys,
As the subject of the topic suggests, im getting a strange noise / interference when i press the button for the Heated Rear Screen.
I have had it for a while now, pretty much ever since i installed the Land Rover half height Dog Guard.
I have removed the dog guard and the noise is still there. I have checked the side windows to see if i have damaged any of the radio antenna etc while installing the dog guard but all looks ok??
Any thoughts would be greatly appreciated!
Paul
Post #47610 26th Jan 2011 12:10pm
seems strange it only started when the dog guard was fitted ..i would concentrate on that and check that nothing has been knocked or any wires crimped.. ... - .- -.
Post #47612 26th Jan 2011 12:16pm
paultuk
Hi Scarey,
Its really strange. The dog guard is attached at 4 points. Two in the roof lining and 2 adjustable straps on the boot so there are no wires in the vicinity of any of these attaching points??
Maybe just a coincidence that it happend when i installed the dog guard?? Could be something else i feel!
Thanks again.
Post #47616 26th Jan 2011 12:24pm
pretty sure the radio aerial is in the window on the near side so could you have banged that somewhere when putting in the guard or the heating screen connections have been dis-lodged.. ... - .- -.
Post #47618 26th Jan 2011 12:39pm
dan_uk_1984
Depending on what trim level you have depends on whether you have the "diversity" tuner option. If you do, perhaps you have dislodged a connection to one of the two aerials?
D
Post #47620 26th Jan 2011 12:42pm
paultuk
Hi Dan,
How would i know if i have the "Diversity" option?? My Car is a 06 Vogue TD6.
Cheers
Paul T
Post #47622 26th Jan 2011 12:50pm
dan_uk_1984
If yours is a Vogue - then yes it will have (I think)
Basically though just open the panel on the left in the boot and make sure that everything is attached. I believe the antenna cables are quite high up and kinda bolted to the side of the car. Vs everything else that is lower down.
D
Post #47639 26th Jan 2011 2:51pm
