![]() | Home > Technical (L322) > 4.4 tdV8 turbo oil drain mod. |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 758 ![]() ![]() |
If you're getting it done under warranty I'd snap their hands off - even if it doesn't fix your symptoms at least it's something that wont cost you later! |
muppet Member Since: 09 Nov 2016 Location: manchester Posts: 90 ![]() ![]() ![]() |
yep, It well definately be done but just wondering if it is the actual issue or just an attempt to fix the smoke in the engine...TA I need more help than most...sorry !! |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2654 ![]() ![]() |
Doesn't sound like the turbo drain symptoms which is purely related to accumulated oil in the inlet to the secondary turbo which gets burnt and produces a smokescreen out the exhaust. Your symptoms are more like the EGR valve/oil cooler oil leak problem or perhaps the turbo oil supply pipe O-ring leak. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
+1 on the above.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3823 ![]() ![]() ![]() |
+2 on the above, but I would definitely get the turbo drain mod done.
