Home > LPG > Lpg injector cleaner |
rik Member Since: 21 Jan 2015 Location: argyll Posts: 265 |
Hi anyone got a recommendation for lpg injector cleaner and where to buy ? |
10th Apr 2018 4:59pm |
Aaron HSE Member Since: 06 Feb 2018 Location: Sussex Posts: 4 |
I have used ic12 in the past. It cleans and lubricates the injectors, you have to put it down the fuel lines coming from the filter to each bank whilst the engine is warm. Comes with instructions anyway. https://rover.ebay.com/rover/0/0/0?mpre=ht...3090815568 |
15th Apr 2018 6:55am |
Cheers Aaron got some ordered will use next week |
15th Apr 2018 8:24am |
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2289 |
Hi Ric. would like to use that stuff as prevention, can you please tell me where you put it in? It sais "pour the fluid in the low pressure LPG line"
22nd Apr 2018 4:19pm |
Hi Robert basically injectors side of filters I held mine up after putting 25mm in each pipe to prevent fluid running back I to filter .Do this twice to each line make sure clamps are tight and you should be good .My rml light went out instantly but is back on car running well so not unduly worried about it .Has been on and off for 6 years so not too worried good luck |
22nd Apr 2018 4:49pm |
