Home > In Car Electronics (L322) > Sat nav loses its position
B100
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
My sat nav seems to forget its last location. I calibrate it so that it is spot on - which it retains until I turn the ignition off. When I start up again, the location might be a few hundred yards off. And within five minutes, it could then be miles off. This happened with the original version of software that came with the car. I updated it to the latest (which I think is about 2014), but it still happens. Everything is fine following calibration, but gets forgotten once the ignition is off. Any suggestions ?
Post #475815 14th Apr 2018 1:19pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
I think you will find it's your Ariel, the reason I say this has I had the same problem with my 2012 VW golf water gets in and cannot find where it is?
Post #475816 14th Apr 2018 2:06pm
jaysta10k
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Could well be your gps aerial on roof unplug it and fit a tampory one here is link below cheap only £4 for one I bought off eBay they are magnetic so just place it on roof temporarily to see if this cures it if so there’s a wiki on here how to feed it into original roof gps aerial mine works spot on now.
https://rover.ebay.com/rover/0/0/0?mpre=ht...2139235815 Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Audi A4 2.7 TDI S Line Black Edition phantomn black
Previous Cars
Range Rover Vogue SE Overfinch Styling 22" Elara's full black stealth colour coded
Java black Range Rover sport 2.7 TDV6
Alaska white Range Rover sport overfinch 3.6 TDV8
BMW M3 Carbon Black
Post #476263 19th Apr 2018 7:18pm
