Home > Maintenance & Mods (L322) > Engine oil
Serg7681
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Engine oil
Hi Guy's
I'm new on this forum
Had engine oil changed last night
Engine done 170.000
4.4 petrol
Put 10w40 ,it's wrong decision ?
Thank you for any advise
Post #475671 13th Apr 2018 9:50am
CS
The recommended grade seems to be 5w40, there will also be specifications to be met, you could call at John Clark LR and ask what they recommend. Maybe in the summer you'd get away with a decent quality 10W40. Only Range Rovers since 1988
Post #475694 13th Apr 2018 12:42pm
j_rov
Here's a full list
https://rimmerbros.com/PopUp--id-444 __
2018 L405 3.0 TDV6 Vogue SE Fuji White
2000 4.6 V8 HSE Oxford Blue
1994 3.9 V8 Vogue Ardennes Green - resto project
Land Rover History:
2010 3.6 TDV8 Autobiography Stornoway Grey
2001 Discovery 2 TD5 GS
1999 Discovery 2 V8i XS
1994 Discovery 300Tdi
1993 Discovery 200Tdi
1989 Range Rover Vogue SE 3.5EFi
1976 Series 3 2.25
1977 Range Rover 2 door 3.5 Carb
Post #475715 13th Apr 2018 2:31pm
Serg7681
Thank you very much Guy's
So do you think I have to change oil right now
Or I can still drive for another couple hundreds miles? 🙄🙄🙄🙄
Post #475719 13th Apr 2018 3:12pm
j_rov
Personally, I'd sort it straight away. However, I'm no oil expert and it might well be fine.
Is £40 worth of new oil worth damaging your engine for? __
Land Rover History:
1976 Series 3 2.25
Post #475720 13th Apr 2018 3:25pm
Serg7681
Can you just explain to me how is 10w40 can damage engine?
Just because is to thick?
But even in manual says you can use 10w
Cheers
Post #475721 13th Apr 2018 3:30pm
m@ttsFF
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
It will be fine unless it gets very cold up there in Aberdeen - the 5w is thinner so flows better when cold 4.2 SC - sold , now bought back
4.4 AdBlu Tractor - Stolen
Post #475725 13th Apr 2018 4:03pm
Serg7681
Thanks for reply
That actuality was my plan trying use 10w on summer time
And change again for( autumn, winter )5w40
But I think lifters on cold start very noisy
Cheers
Post #475726 13th Apr 2018 4:10pm
