Home > LPG > Bit of advice re K&N style filters
simonday
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
Hi,
My 4.4 o4 stopped working at busy junction today (could have set fire to it but have forgiven now) and mechanic mate came and unplugeed the mass airflow sensor which made it tick over. Horray we can now get home! Little victories. I am however now looking for a new Air Mass flow and have put up a post and just generally wondered if anyone had any advice re these with LPG and also the fact that I noticed mine has a metal K&N style air filter and whether this is a good idea with LPG or not.
Thanks in advance
Simon
Post #475326 9th Apr 2018 8:09pm
Dolphinboy
simon,
I have a K&N airfilter because of space restrictions due to the LPG fit. It works fine (only cost £35 as a special sale item on Ebay.) I also replaced the MAFF (at a cost of £46 + Vat + Labour so get a new one, Pref OEM or bosch.
Post #475378 10th Apr 2018 4:54pm
MR GLOVER
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
How do you keep it that cleeeeeeen ????????????????????? Thumbs Up
Post #475387 10th Apr 2018 6:03pm
wood78987
United Kingdom 2012 Range Rover Westminster TDV8 Stornoway Grey
Hi Simon,
Did you manage to get a new MAF after?
I'm not sure if you've seen this thread, but after cleaning the cone filter, things seemed to settle down for me.
http://www.fullfatrr.com/forum/topic41965.html
Hope it's running well for you other than the MAF. 2012 Westminster 4.4 TDV8
Post #476107 17th Apr 2018 8:27pm
simonday
Hi,
yes sorted the Maf with a new Bosch one and now fine thanks. Wish id have kept the old one now as maybe woudl have cleaned/got it back working? or once they go are they gone?
S
Post #476109 17th Apr 2018 9:04pm
wood78987
Yes, once they are gone they are gone.
But its worth keeping the cone filter clean, every 3-6 months or so.
Clean it in a bucket of soapy water, but make sure it's thoroughly dried before refitting it, ideally with a hot air gun.
And don't even think about oiling it like a K&N filter as that will very quickly destroy the MAF again. 2012 Westminster 4.4 TDV8
Post #476110 17th Apr 2018 9:14pm
wood78987
Forgot to add.... make sure the filter is thoroughly rinsed of any soap residue too.
Maybe a bit OTT but I used to sit it in a bucket of clean hot water for a while then blast it with the hose pipe afterwards. 2012 Westminster 4.4 TDV8
Post #476111 17th Apr 2018 9:21pm
