Home > Technical (L322) > Brakes groaning
cheezels
Australia 2007 Range Rover Vogue TDV8 Java Black
Brakes groaning
I fitted new pads and rotors a few months ago.
All has been well until recently whereby there is a groaning sorta juddering just as the Rangie comes to a stop.
Doesn’t happen under hard braking, just light braking juuuust as she comes to a standstill.
“All makes” rotors and land rover pads were fitted.
The rotors I removed were brembos and a similar juddering/groaning happened with them.
Anyone else experienced this?
Any pointers on how to rectify appreciated. 2007 3.6 TDV8
Post #475199 8th Apr 2018 9:51am
nino_nino
cheezels,
your disks may be "dirty" brake pads material deposits on the disks. accelerate to ~80 mph, apply brakes with increasing pressure, when the speed drops to ~25 mph accelerate again and repeat procedure, do this 3-4 times. do this in a safe place please.
Nino,
Post #475211 8th Apr 2018 1:38pm
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
It might be worth checking the condition of the rubber bushes in the front suspension upper arms.
If things can move around more easily, low frequency noises can be made louder. Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #475213 8th Apr 2018 2:27pm
cheezels
Finally got to the bottom of this
Tried bedding in the pads and discs using various techniques - no joy
New discs and pads (Bendix HDs with titanium auto bedding) - no joy
Replaced the dampers on the top of the struts - joy!
See picture below
 2007 3.6 TDV8
Post #477169 30th Apr 2018 8:54am
didnt expect that.....how did you figure it out? ... - .- -.
Post #477170 30th Apr 2018 8:57am
cheezels
I had a hole in one of the struts. Fitted new ones, but couldn’t remove the dampers from the old struts to transfer to the new ones.
Didn’t think they did too much, but they were referenced a few times in the workshop manual in the brakes section. Just a couple of words and nvh (noise, vibration, harshness). They are only fitted to vehicles with “high performance brakes”.
I was experiencing the groaning with the old struts (and dampers) so I was more focused on the discs and pads and drivability wasn’t compromised without the dampers (it was actually a bit better as the struts were new)
Anyhoo, Duckworths Dan sourced some new dampers and I fitted them today.
Really surprised they are more for braking purposes rather than handling/ride comfort 2007 3.6 TDV8
Post #477176 30th Apr 2018 9:30am
interesting... Thumbs Up ... - .- -.
Post #477179 30th Apr 2018 9:49am
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
Can I ask - what constitutes "high performance brakes" or, more importantly, how would I know if I have them or not? Whistle 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #477189 30th Apr 2018 10:14am
MikeO
Attempting to answer my own question, I see in the Workshop Manual the following:
"All models feature ventilated front disc brakes. 4.4L V8 naturally aspirated vehicle use twin piston sliding calipers and brake discs. 4.2L V8 supercharged and TdV8 vehicles use 4 piston, opposed piston Brembo calipers and larger brake discs. These vehicles also have a mass damper attached to the top of each front suspension strut to improve noise, vibration and harshness (NVH) when braking. For additional information, refer to: Front Suspension (204-01 Front Suspension, Description and Operation)"
So presumably I have high performance brakes? The front caliper looks to be much larger in the pictures in the workshop manual so should be easy to confirm.
I'm curious because I've noticed a very slight juddering sometimes as I come to a stop... 2016 Skoda Octavia VRS Estate
Post #477190 30th Apr 2018 10:27am
cheezels
Yep, you answered your own question.
You can easily check out if you have the damper by pulling off the plastic dome shaped cover from the top of the strut, in the engine bay. 2007 3.6 TDV8
Post #477336 2nd May 2018 9:58am
Harlin
England 2006 Range Rover Supercharged 4.2 SC V8 Java Black
nvh
this is the best news ever Bow down Bow down please can yon give me the part no:
Post #477373 2nd May 2018 6:34pm
Harlin
Stan hi, sorry for my ignorance but my fattie has the same problem with the groaning, I am not sure how to start a chat with duckworth dan as i think from reading this thread he supplied the part i need, i would like to ask him a couple of questions and would rather do it on the thread so other people can see it too
thanks rob
Post #477378 2nd May 2018 7:46pm
cheezels
Here’s a screenshot. Item number is highlighted (I’m not sure what the part number is, but Dan will have it)
I’m not suggesting this will cure all braking noises for you, but it certainly cured mine.
Re contacting Dan. If you scroll down the home page you’ll find him in site sponsors. Click the link and the next page will list various threads. At the top of the page there will be a new topic button 2007 3.6 TDV8
Post #477380 2nd May 2018 8:32pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
well up until yesterday I had a similar issue , brake squeal under light braking but not heavy braking , I removed all the pads , re-copper greased them all and all is quiet again
Post #477387 2nd May 2018 10:08pm
Tight777
Don't think this relates to squealing, more a judder,groaning under braking.
Post #477481 3rd May 2018 9:28pm
