Home > Technical (L405) > 2014 Autobiography Tailgate problem |
CMJ Member Since: 10 Oct 2010 Location: Lancashire Posts: 208 |
Maybe be obvious but the boot doesn’t work when In drive. You need to be in park if the engine is running. Both the remote and button under the dash will open with the engine running but only when in park. No reset that you can do yourself as far as I am aware. 2013 L405 AB 4.4SDV8 Luxor/Ivory, 2007 Vogue TDV8 Epson Green/Sand, 2008 Vogue TDV8 Buckingham Blue/Sand, 2003 Vogue 4.4 LPG Epsom Green/Sage, 1998 Vogue SE 4.6 LPG Epsom Green/Cream |
3rd Apr 2018 9:09pm |
Red Maverick Member Since: 21 Sep 2017 Location: Liverpool Posts: 13 |
Hello
3rd Apr 2018 9:12pm |
I decided to call Land Rover Assistance to see if this was a common problem that one of their tech guys could sort. Was told that a technician would not be available until tomorrow night. In the meantime they sent an AA patrol. A very helpful guy turned up who had phone access to LR technical guys. He went through lots of steps but all to no avail. He advised booking it in with the main dealer to resolve. Bit worried about that as my local LR main dealer has proved to be a bit problematic in the past - but unless there is a miracle reset out there, I guess I have no choice.
3rd Apr 2018 9:41pm |
harrymomsen Member Since: 19 Jul 2017 Location: Frankfurt Posts: 4 |
Its a low battery ! I have seen this myself - the battery management of the car shuts down every electrical system which is not necessary in the moment and you can only move the tailgates manually. The car beeps and in the control display you can see "Low battery - start car immediately". When the battery is loaded again, the tailgate works as usual. |
5th Apr 2018 8:34am |
Fleagle_UK Member Since: 20 Mar 2013 Location: Cheshire Posts: 409 |
The holding down of the lid button down isn't actually reset of the system, its to re calibrate the height you want the lid to open to (when it does work that is)
5th Apr 2018 10:48am |
Hello
5th Apr 2018 9:31pm |
There are others much wiser than me on this forum but I don’t think it’s straight forward as it once was to change the battery(s). Once changed you have to tell the battery management system (bms) what the spec of your new battery is so it can do all its calibrations etc.
5th Apr 2018 9:59pm |
From LR Topix, these fault references might assist:
6th Apr 2018 8:32am |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 |
Batteries replacement procedure would be useful to everyone here indeed. l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
6th Apr 2018 8:48am |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 |
Did this get resolved?
26th Jun 2018 3:02pm |
Finally got this fixed!
12th Oct 2018 3:16pm |
