Home > Maintenance & Mods (L322) > No rear washer jet
Tight777
No rear washer jet
I've done a search and come up with lots of posts with problems with rear wiper and wash but dont seem to find an answer for mine.
Rear wiper works fine.
I have water exiting the one way valve to the motor.
I've checked the jets aren't blocked.
so it appears the blockage is through the motor itself?
Is that a common problem with a fix or is it a new wiper motor req?
Post #474972 6th Apr 2018 8:42am
mpirie
Yes, it's a common problem.
Take it apart and use plenty of thin wire or compressed air to clear out the blockage.
No need to replace the motor.
Have a look in the Wiki, there should be some guidance in there.
Mike
Post #474974 6th Apr 2018 9:07am
Serg7681
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Try use powerwash with a good blast, it's work for mine one
Had similar problem😁😁😁😁
Post #475877 15th Apr 2018 8:43am
