Home > In Car Electronics (L322) > Sat Nav keeps reverting to Belgium
sirchatalott
United Kingdom 2007 Range Rover Vogue Td6 Baltic Blue
Good evening, morning or Afternoon,
My 2007 L322 TDV8 has a problem, the Satnav keeps reverting to Belgium does anyone know what is causing it, and how do I stop it?
I am in the UK.
Post #474601 2nd Apr 2018 8:54pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Hi, I had the same problem with my GTD Golf, Turned out to be the aerial which gets water in, still got radio but not GPS,
So got a part from Fleabay removed the GPS connection and connected the plug straight in which worked straight away.
But if you would rather pull the headlining down to replace the aerial my fix was cheaper for the Golf, could be a way to go?
Worth looking into?
Post #474605 2nd Apr 2018 9:24pm
It’s been mentioned a few times on here, have a search and see if anything relevant pops up👍🏻 There is nothing that can't be fixed with a hammer😜😜
Post #474608 2nd Apr 2018 9:49pm
