Home > Technical (L322) > A Possible Blown Head Gasket? - Still unsolved |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1379 |
I also personally think that you need a themostat in there for whole the system to work properly. You can easily fit a lower temp one that is a direct replacement for the existing one ( with zero modifications or extra bits ). I put a thread up on here years ago about it. And others have done other similar methods.
26th Mar 2018 8:36am |
desertdude Member Since: 10 Sep 2016 Location: Dubai Posts: 60 |
Fisha, Ive been running without a stat for over a year now with 0 issues. So dont think its a stat issue. |
26th Mar 2018 8:43am |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
There are a number of products that claim to repair a leaking headgasket and some i have heard of actually working so although not an ideal solution it is certainly cheaper and easier than removing both heads.
26th Mar 2018 5:10pm |
Nah I rather not gum up the system, although I did use a radiator sealant long time a ago in my land cruiser and it lasted for years.
26th Mar 2018 5:55pm |
m@ttsFF Member Since: 12 Dec 2017 Location: Surrey Posts: 329 |
Yep - always worth replacing 4.2 SC - sold , now bought back
26th Mar 2018 5:57pm |
i have the 140 cap in mine and worth trying
26th Mar 2018 6:15pm |
I dun't think plugs will tell me anything, engine runs smooth and pulls like an ox. With the iCarsoft plugged in all cylinders are giving out readings like they should and there are no codes logged either, plus I dont have a spark plug or deep socket spanner!
26th Mar 2018 6:27pm |
This is a similar engine
26th Mar 2018 6:54pm |
Interesting! Might be worth a shot, only problem is ( and I have looked ) this isn't available locally which means an expensive when you add international shipping song and dance and a loooong gamble to see if it actually gets here.
27th Mar 2018 2:09pm |
Update : Ive ordered a Bars Leak HG1 will take a couple of weeks to reach hear. I the meanwhile I was able to get a new rad cap but rated 200 or 2 bar. Quite a lot of coolant had been spurted out and it was late night so refilled and did a very basic bleed and put on the new cap a slow 15 drive around and the coolant wasnt spurting out nor tye cap hissing the system was super pressurized. The top hose had swelled to resemble a cobra at the radiator connection. So undid the screw a lot of airbubbles came out but I only let off enough pressure so the pipe could return to normal size. But still stiff to the touch.
8th Apr 2018 10:15am |
Rlmichot Member Since: 14 Oct 2018 Location: LA Posts: 9 |
Did you happen to figure out the problem? I'm having the same symptoms, water coming out of the cap once hot & the upper radiator hose getting rock hard. |
14th Oct 2018 10:58pm |
Signs point to a head gasket but it runs to good! No water in the oil. Only a tiny drop of water out of the exhaust every once in a while |
14th Oct 2018 11:00pm |
ivan1566 Member Since: 15 Feb 2019 Location: Dubai Posts: 19 |
Did you ever get this resolved?
3rd May 2020 5:57am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8287 |
I'll chuck my 2p worth in
3rd May 2020 1:30pm |
