Home > Maintenance & Mods (L405) > Advice on new windscreen
AMD
Hi, Car returned from dealers on Friday, major service, MOT, all good.
They found a loose connection on the the windscreen which was fixed, I’m told it will now heat both sides. I am guessing this was caused when National Windscreens replaced the screen last year.
They also renewed the 2 gas struts to the rear tailgate and adjusted it so it no longer rubs on the pillars all under warranty.
I have to say, good service from Inchcape Southampton (formally Hunters) Thier new service manager from Porsche seems to be making a difference! Current MY2020
Gone: 1 x L405 and 2 x L322's
Post #473810 25th Mar 2018 12:56pm
Mariana Black
England 2014 Range Rover Autobiography TDV6 Mariana Black
Pleased all is sorted AMD
This give me the incentive to go digging deeper.
Nice to know there are some main dealers that still able to help after sales.
3.0 14M5 Autobiography
Post #473864 25th Mar 2018 7:18pm
Most likely culprit is a connection - you can easily remove the pillar cover, there's a bolt behind the Airbag badge which just prises off
There are 2 connectors - one does the wiper area only, the other does the entire screen - so it may be not connected - or maybe on the wrong connector
It's easy to test as you can feel the heated area with your hand
Post #473868 25th Mar 2018 7:34pm
Mariana Black
Sorted my windscreen not working.
National windscreen had connect the wrong cable to the element. Embarassed
In the passenger A pillar there is one spare connector (This is the one they have found) The correct cable had been tucked down near the side of the vent.
Just for fun on the Drivers A pillar there are two spare connectors - lucky they found the correct one but managed to trap the wires into the air vent.
Now happy but not impressed by National windscreen care and attention. Sad
Thumbs Up Thumbs Up Thumbs Up
Post #489543 22nd Sep 2018 9:46am
