Home > Maintenance & Mods (L322) > Oil filler cap hard to remove
petewild
England 2002 Range Rover HSE 4.4 V8 Java Black
Apologies if this has been posted or asked/answered before, but whenever I have a need to top up or fill the oil, the filler cap is an absolute Censored to undo.
I cant figure out if its sticking or just because its in such an awkward place to get hold of it to turn it, but its a mare to get off every time.
I even resorted to making a 'tool' that fitted over the cap to give me some leverage, but it was so tightly wedged on, the tool bent before it turned the cap.
Soooo, wondered if anyone had any bright ideas or clever ways round it, or is mine the only sticky one?
Post #473453 22nd Mar 2018 5:53pm
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
Is it under pressure? You may have a blocked breather. It should never be that tight it bends a tool. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #473464 22nd Mar 2018 7:18pm
petewild
Hi Grofus,
Thanks for the reply.
Would it be under pressure even when the engine isnt running? Or am I being dumb Embarassed
Would a blocked breather cause an oil drip underneath? I have always had a drip now and then, but lately, its a drip, drip, drip! Ive crawled under but you know what its like trying to find the source of things, hoping to get it on a ramp soon which might help.
Ill be honest, Im running this beast on a real budget so cant afford the 'correct' way to maintain it other than the obvious and necessary things.
I expect Ill get some comments like "If you cant afford it, dont buy it" but I love it never the less, and the tears and money spent is easily outweighed by the joy of her when she is all up and running.
When I say 'tool' it isnt a tool as such, just a couple of bits of metal I bolted together to span the cap and give me something to get a pair of grips on, but it obviously wasnt man enough.
Post #473469 22nd Mar 2018 7:58pm
Grofus
A blocked breather will cause oil leaks and make the cap hard remove. Its why bottles of fizzy drink have the relief channels in the neck. Same thing applies here.
Sounds like you have blocked breather problems to me. Do you get " mayonaisse" collecting under the cap when you do get it off. If so, then definitely look at the breather tubes and valves. Positive pressure in an engine isn't good. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #473470 22nd Mar 2018 8:06pm
petewild
Top fella
I shall investigate that bad boy then !
Once I figure out where the hell it is ! lol
Cheers once again
Post #473473 22nd Mar 2018 8:10pm
Grofus
posted it twice somehow!!!!! Shocked 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #473474 22nd Mar 2018 8:10pm
Mine has always been a bit of a b@gger to undo, usually resort to the plumber's wrench to loosen off. fortunately never use any oil so only have it off at service time Thumbs Up .
Post #473510 22nd Mar 2018 10:32pm
Clivefog
I use water pump pliers on full opening. Can't use my hands as they are old a full of pain. Vent is clear and neck is smeared with oil on refit but still sticks.
Post #473613 23rd Mar 2018 5:19pm
at least if it's tight it won't come off and spurt oil every where... ... - .- -.
Post #473615 23rd Mar 2018 5:38pm
^^^^^ said the actress to the bishop!! .
Post #473620 23rd Mar 2018 5:54pm
Laughing ... - .- -.
Post #473626 23rd Mar 2018 6:48pm
petewild
The winners for the best suggestion goes to Joe and Clive, just tried the water pump pliers and worked a treat, thanks !
Looking at them now I cant honestly think why it never occurred to me before but that's the good thing about this site, full of good ideas and bloody clever people !!
Now onto the next suggestion, the breather pipes !
thanks again.
Post #473635 23rd Mar 2018 7:53pm
doclees
United States 2004 Range Rover HSE 4.4 V8 Java Black
Mine is a pain too and there isn't any space for leverage. I had a small rubber strap wrench that worked. It broke so I need another one.
Post #473646 23rd Mar 2018 8:59pm
