![]() | Home > Technical (L322) > Problem Part 2 (Hum/buzzing) |
For the HVAC i'm pretty sure its under that grill on your bonnet near the windscreen.... |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3199 ![]() ![]() |
I had a really annoying buzzing for a few days over Xmas and it was speed/wind related. It was the rubber finishing at the front of the rail gutter on the roof which had come unstuck by about 1 cm and was bending up and catching the wind. could be this? I cured it by sticking it back down and now no noise. |
Captain Slog Member Since: 16 Jul 2010 Location: Derbyshire Posts: 49 ![]() ![]() ![]() |
Thanks for the heads up I think that I checked the windscreen rubbers ect but I will re-check this. ![]() _________________ Currrent: 2005 FF Range Rover L322 Vogue TD6 Gone: 1999 Range Rover P38 HSE TD6 Gone: 1985 Land Rover 90 SWB diesel |
Its the harder bit of plastic casing that clips down below the screen that is the problem. If they have been pulled up during a service/repair they are often not reseated properly.... |
As stated in my original post I have checked roof pillar trim but I will re-check this area again. Thanks for the reply ![]() _________________ Currrent: 2005 FF Range Rover L322 Vogue TD6 Gone: 1999 Range Rover P38 HSE TD6 Gone: 1985 Land Rover 90 SWB diesel |
Tends to be the piece along the bottom of the screen.... |
oodathort Member Since: 01 Nov 2010 Location: just there Posts: 191 ![]() |
front scuttle |
David Member Since: 15 Oct 2010 Location: Murcia Posts: 301 ![]() ![]() ![]() |
Had the very same noise on mine, sometimes its there, sometimes its not ! Just live with it now ! 2007 TDV8 Vogue SE |
After the useful replies I decided to check the two areas suggested.
Thought it would be the Scuttle as I had same. Mine just needed clipping down properly |
This is the strange thing, everything seems tight, there is no movement in the scuttle at all, the rubber seal is also tight against the windscreen although the noise did stop when I taped as stated. ![]() _________________ Currrent: 2005 FF Range Rover L322 Vogue TD6 Gone: 1999 Range Rover P38 HSE TD6 Gone: 1985 Land Rover 90 SWB diesel |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1749 ![]() ![]() ![]() |
Interesting post - funny how it was an exact same issue on the P38's. Mine had it..! Scuttle it was. Ash
Could try running some of the black sticky |
