Home > General (L405) > 2016 TD6 common problems |
doclees Member Since: 24 Jun 2015 Location: PA Posts: 672 |
So I will probably in the market for a 2016 fullfat td6 in about 2 years. "Upgrading" from my 2004 fullfat 4.4. What are the issues to prepare for with this model. Only thing I found from car and driver review was the electronics. Are the that abysmal and are they correctable/upgradeable? It will have in the neighborhood of 100k miles +-. Thanks |
21st Mar 2018 2:12am |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1140 |
Live in the states and want the TDV6 ? Get a petrol as DB says . TD6 , some have suffered crankshaft snaps |
21st Mar 2018 11:11am |
Oh crap. You are bursting my balloon. I wanted that range rover feel with 30mph US. |
21st Mar 2018 2:30pm |
martinf Member Since: 26 Dec 2014 Location: sussex Posts: 256 |
I actually have the 2016 MY L405 with the 3 litre diesel and am very pleased with it after 33,000 miles. No problems, very smooth (probably smoother than the v8 ) and more than enough power; and ours spends a lot of time towing horses about. |
21st Mar 2018 4:39pm |
No electrical gremlins? |
22nd Mar 2018 1:06am |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
Yes, that's about the TD6's maximum speed. |
22nd Mar 2018 4:27am |
The electrical socket for the tow hitch was faulty on delivery and the onboard service due indicator does not work correctly. There is a fix but I can't be bothered to take it in. Otherwise all good. |
22nd Mar 2018 1:05pm |
Oops. 30 MPG. Although I do drive like the boot is full of nitroglycerin. |
22nd Mar 2018 5:09pm |
JamesD Member Since: 21 Jan 2013 Location: Worcestershire Posts: 203 |
Same here 2016 model with 30k miles....no issues at all engine wise. Only 1 problem when the tailgate lost synch but that could happen to any L405. 2021 L405 Vogue D300 2016 L405 Vogue 3.0TDV6 (Sold) |
29th Apr 2018 7:42am |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1385 |
Search on here for threads about TDV6 engine failures/seizures and there is a current thread about engine oil being diluted with diesel leading to reduced service intervals/engine wear. Maybe also look at Discovery and RR Sport forums, that engine is used very often in those applications, though I recall reading that the less spacious engine bays there might cause more problems than in the 405. Only Range Rovers since 1988 |
29th Apr 2018 6:12pm |
The TSB seems to imply it was a rare event from improper factory install of the bearings. I would assume if it hasn't broken by the time it hits 76k or more, when I'd be looking to buy, it's not one of the problem motors. |
30th Apr 2018 12:40am |
