Home > Maintenance & Mods (L405) > Wheel alignment recommendation Cheltenham / Cotswolds
JCW
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
Does anyone have a recommendation for somewhere trustworthy / competent to carry out a full wheel alignment on a L405 in the Cotswolds area / Gloucestershire / Oxfordshire borders?
Just changed all four wheels / tyres with a brand new set and the original tyres are showing some increased wear on the outer edges, steering wheel is also not 100% central travelling in a straight line.
Thanks
Post #473008 18th Mar 2018 11:22am
Dolphinboy
Pro tyre did a good job on my previous rr.
Post #473020 18th Mar 2018 12:42pm
JCW
Was that at the Gloucester branch?
Post #473027 18th Mar 2018 1:41pm
Dolphinboy
No Brizzle- but they should have the same kit so should be ok?
Post #473028 18th Mar 2018 1:45pm
Chris Mullins Tyres on the Bristol Road do all of ours Thumbs Up
01452 529537
Thumbs Up Thumbs Up Thumbs Up
Post #473031 18th Mar 2018 2:47pm
JCW
Ok, thanks guys, I'll check out both in the morning Thumbs Up
Post #473036 18th Mar 2018 3:19pm
FYI Chris used to run Pro Tyre in Glos and left taking all the decent staff with him... That is why we use them... Thumbs Up
I don’t have any affiliation with either business by the way Thumbs Up
Post #473040 18th Mar 2018 3:47pm
JCW
Thanks Craig, I'm leaning towards Chris Mullins, as its slightly closer in anycase.
Post #473045 18th Mar 2018 5:28pm
Fleagle_UK
United Kingdom 2014 Range Rover Autobiography SDV8 Luxor
Re: Wheel alignment recommendation Cheltenham / Cotswolds
Just be mindful that "some" wear on the outer edges is probably normal and NOT always a sign (on its own) that you need an alignment. Many RR's (older L322s could be dreadful) can be quite harsh on the outer edge of the front tyres particularly the passenger side thanks to our wonderful roundabouts with a big heavy car.
Post #473098 19th Mar 2018 1:00pm
JCW
Thats an interesting point, I'll be keen to see the pre & post alignment settings to see how far out they may be and how normal edge wear is on a correctly setup L405.
Post #473134 19th Mar 2018 7:25pm
But if you keep your tyres rotating, side to side - front to back etc etc... Then they should run out quite flat and not feather the edges... I have several 405 customers running 40k+ miles on a set of tyres... Thumbs Up
Post #473168 20th Mar 2018 12:23am
RichTDV8
United Kingdom 2015 Range Rover Vogue SE TDV6 Corris Grey
Elite Tyres at Reading. They do all the Aston and Lambo work for Pangbourne and did my 20 inch rims with grabber AT3’s. They are fantastical about tyres and alignment. Really good 👍👍 Previous
2008 TDV8 Vogue
2011 TDV8 AB (former LR1)
3.0VSE - 2015MY
Corris with Black, RSE, 22 turbines, privacy, deployables
2023 L460 P400 SE in silicone silver
2022 L460 P400 AB in black with ivory (fully loaded with deleted rear exec pack)
Post #473647 23rd Mar 2018 9:46pm
The OP asked for wheel alignment in the Cotswolds area sir... Whistle Thumbs Up
Post #473656 23rd Mar 2018 11:04pm
chopdogs
Car Care Tetbury do a full four wheel alignment.
Post #473657 23rd Mar 2018 11:12pm
JCW
Just to revive this thread, had an alignment this morning at Chris Mullins in Gloucester, efficient service and as nothing actually needed adjusting as it turned out, only charged me £15 all in.
P.s. Craig, I mentioned your referral & Chris’ immediate response was ‘what Craig doesn’t know about RR’s isn’t worth knowing’!!!
Post #617383 23rd Dec 2021 3:42pm
