Home > Technical (L322) > PUT UNLEADED FUEL IN 3.6TDV8, Cant find much info - thoughts |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
Very bad for a common rail diesel engine. |
18th Mar 2018 7:22am |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3750 |
As above - it's extremely likely that at the very least the Diesel Fuel Injection Pump will be severely damaged - they rely on the diesel as a lubricant.
18th Mar 2018 8:55am |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1347 |
My good lady wife once managed to fill one of our diesel vans with petrol one time , I drained the tank and filled with diesel and the van was 100% no issues whatsoever BUT that was our fault and not a great expense if it died 3 month down the line.
18th Mar 2018 9:10am |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 |
I used to work as a contractor for a couple of landrover dealers years back when the TDV6 / TDV8 's first came out.
18th Mar 2018 9:14am |
Spooky Member Since: 03 Aug 2009 Location: Swindon, Wilts Posts: 190 |
Big oops on the part of the fuel station! I'd imagine that they'd be liable for the damage, too - they certainly would be in the UK; surely Ox will be similar ...
18th Mar 2018 12:11pm |
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 439 |
You didn't drive very far so Imo drain the tank, change the filters, and all should be fine.
18th Mar 2018 9:33pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7944 |
Given the circumstances, I'd find a local main dealer and have them quote.
19th Mar 2018 6:45am |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1773 |
And if the HPFP has been stripped of lubrication, it will have put microscopic metal fragments through the whole fuel system In the event of a misfuel, the WHOLE system needs replacing. HPFP, LPFP, injectors, even down to the fuel lines and fuel tank (especially if someone else is paying) |
19th Mar 2018 8:25am |
Bill Member Since: 18 Nov 2017 Location: Essex / Normandy Posts: 1233 |
In the worst case.....I hope you have written to them with registered post or similar.... you don’t want them to forget in 6 months time.
19th Mar 2018 10:05am |
Paulus1978 Member Since: 09 Nov 2017 Location: Leicester Posts: 89 |
I used to work for a Jaguar Main Dealer. When they first launched the 2.7 V6 TD in the S-Type and X350 we had no end of owners put Super Unleaded in thier new beast purely out of habit. Regrettably as other have said, I can confirm the high pressure pump uses the Diesel as a lubricant and consequently starting it with the wrong fuel just leads to the death or serious injury of the pump and (because of metal fragments breaking away from the now non-lubricated pump) the injectors too. If the owner realised thier mistake and didn't turn the key in the ignition and prime the pump, we could drain and flush the low pressure side of the system. If it made it into the High Pressure side, we replaced the components and the owner would usually have a bit of an argument with the Insurance Company and ultimately get paid out.
19th Mar 2018 2:38pm |
Billaboard Member Since: 03 Aug 2017 Location: Wirral Posts: 74 |
I'm sure this is obvious, but the very first thing to do is get the till receipt for the fuel. If you haven't got one, the garage might be able to provide a copy.
19th Mar 2018 5:11pm |
