Home > Technical (L322) > Suspension
chefkenmore
Scotland 2014 Range Rover Vogue SE SDV8 Loire Blue
Suspension
Hi guys, in a pickle right now with imminent holiday with the caravan on Monday !
Having issues with the suspension, can’t get it to calibrate seems to be locking me out! Have this fault!
Messages on dash are
Car will lift when system cools down
Suspension fault and something like reset when obstacle cleared!
Car is sitting at almost ride height but won’t do anything else!
Any help would be greatfully received and let us go on holibags
Many many thanks
David 2014 vogue se
Post #472896 17th Mar 2018 9:23am
Have you been asking it to go up and down on the drive in quick succession?
Go for a ten min drive, leave it alone don’t press Any thing then try it as you pull into the drive.
Compressor overheat usually happens when it’s racing to refill the tank after going up and down too much. There is nothing that can't be fixed with a hammer😜😜
Post #472898 17th Mar 2018 9:41am
cheezels
Australia 2007 Range Rover Vogue TDV8 Java Black
I had the same issue. In my case it was a leaking air bag.
In Offroad height I could hear the leak.
The compressor will reach it’s safe maximum temperature and disable itself until cooled down. Just a feature to stop it self destructing.
Here is a bit of diagnostic help I got from GAP
C113066 Air Spring Air Supply
Repeated or frequent level activity in the up direction
Air spring leak
Air harness leak
Exhaust valve stuck open
Corner valve leak to gallery
Visually inspect the system for air leakage.
I have the IID tool and used it to lower the suspension a little to ‘stop’ the leak until my new struts arrived.
If you’ve been calibrating it could just be you’ve taken a bit too long and the compressor has struggled to keep up with the air demand.
Hope that helps 2007 3.6 TDV8
Post #472937 17th Mar 2018 2:55pm
Mikey
Air leak or wonky height sensor Thumbs Up
Run the engine, monitor the current ride heights and/or voltages. They should all be fairly static. If that’s fine...
Attempt off road height. If there is a bag leaking, it should be fairly evident
Post #472940 17th Mar 2018 3:03pm
chefkenmore
Thanks guys for the input!
Burst front offside spring! Blew it up and air hissing from it!
New spring time Big Cry 2014 vogue se
Post #472949 17th Mar 2018 4:37pm
