![]() | Home > Technical (L322) > can you swap front air springs? |
I just looked at my old air springs (I used the arnott replacements last summer - http://www.arnottindustries.com/part_LAND_...id159.html 2nd item down), and while the springs themselves look the same L&R (numbers were illegible in the rubber) and might work, the bigger problem is what's inside: the arnott replacements come with what are under dimensioned bump stops IMO (top piece in the small parts on the pic) so that the bump stops which sit on the cartridge rod (shock absorber rod) fit through the lower hole in the air bags. The bump stops are more like coil spring bump stops- meaning that in the event of an EAS fault that drops the car to it's bump stops I will have NO suspension left. The OEM units are much larger and do not fit through the lower hole. I assume the metal clamp around the spring/strut bearing at the top is installed after the spring is mounted on the cartridge and the bump stop installed from the top.
herman maire Member Since: 28 Nov 2010 Location: up north Posts: 51 ![]() ![]() |
Hi Steve,
The springs themselves are great. The bump stop is under dimensioned and so is the silly push nut that holds the spring on the lower perch. Everything else is OEM or +.
Steve,
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 ![]() ![]() ![]() |
Given your tempretures maybe a frozen valve block due to moisture in the system could be adding to your leaking spring woes. Can you get it indoors for a while to thaw then check? 2010 Disco XS TDV6, 2009 Freelander 2 GS
Thanks for the reply.
