![]() | Home > Technical (L322) > Lumpy idle and no throttle response |
Johnsd1v8 Member Since: 06 Jul 2017 Location: Cheshire Posts: 190 ![]() ![]() ![]() |
Have you blanked the egr fully off aswell as having it mapped out |
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 ![]() ![]() ![]() |
You can't blank off the EGRs on a 3.6 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35373 ![]() ![]() |
i think you can stick egr emulates on ...someone down under did it.. ... - .- -.
Well thats new to mate i was told you can do it just like the td6 |
Andyyav Member Since: 13 Mar 2017 Location: Norfolk Posts: 138 ![]() ![]() ![]() |
Confused.....so the egrs are mapped out and not working but could still be causing the issue?
Update- I replaced both MAP and MAF sensors and all was well......then today I started it when it was warm and the revs sat at about 500 then after 30 secs or so returned to normal....it was no where near as bad as the first time. I’ve borrowed a very basic code reader and there’s nothing registered.... I’ve read on another thread that it could be related to the battery I’ll get that checked next!! |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1378 ![]() ![]() |
Could also be the throttle body itself. Certainly on the Td4 freelander engines, the toothed gearing and sensors within it could wear out causing issues with starting and throttle response. Also, cause of the nature of the diesel, oils and gunk can build up around the butterfly causing it to stick.
Thanks for all the infos and advice!
Highgun Member Since: 07 May 2018 Location: Broxbourne Posts: 1 ![]() ![]() ![]() |
Did you find out what the fault was Andy? I have the same problem with mine. |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3237 ![]() ![]() ![]() |
https://www.ebay.co.uk/itm/RANGE-ROVER-Vog...2749.l2649 John 2008 Stornoway Grey 3.6 Tdv8 Vogue 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT 2003 Discovery TD5 Auto, Nanocom Evolution - gone to a new home! MasseyFerguson 152 - No electronics!! - Sold |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4306 ![]() ![]() ![]() |
Bell Auto Services are your folks to do this. Ian Bodsworth is an agent for them too |
Apologies highgun not been on for a while, I ended up parting company with mine, was advised the torque converter was at fault after the Rev problem got worse and I was getting vibrations under acceleration, moved on to a D4 but still miss it |
