![]() | Home > Technical (L322) > Changing rear disks with Electronic Parling Brake? |
Webbie Member Since: 02 Apr 2016 Location: Corby Posts: 137 ![]() ![]() ![]() |
Is it a straight forward job to change pads and disks with when I have an EPB set up (MY 2011 TDV8)? I only have the most basic of DIY experience and no IID.
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 528 ![]() ![]() ![]() |
It's a pretty straightforward job - the EPB doesn't really come into it much aside from [a] making sure it's off and can't accidentally come on [b] adjustment procedure [c] bedding in procedure. There is a very good document on disco3.co.uk written by member Bodsy called "Bodsy's Brake Bible". It's specific to the D3 but there is a lot of commonality and it will give you a sense of the job.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
for the DIYer, its called an ELECTRONIC HB so, if you disconnect the battery! The electronic bit won’t work whilst you do the job |
Thanks one and all, I will brave the task armed with the additional knowledge. |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
When I did the rear discs and pads on mine, I left mine in 'N' with the EPB off, parked on level ground (wheels chocked) and nothing more.
You should really pull the fuse or disconnect the battery to be safe and also do the EPB adjustment when you're done. It's not difficult if you already have the wheel off. I found it easier on the D3 though as you can get a 32mm socket on the hub and turn until a set resistance is achieved and then back off the adjuster. The FF approach feels a bit less scientific. 2016 Skoda Octavia VRS Estate
