Home > Technical (L322) > Air Suspension Fault Help |
Lew306red Member Since: 26 Feb 2017 Location: Tamworth Posts: 10 |
Hi everyone.
8th Mar 2018 6:36pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
First, have a look at the height sensors, especially the one that is on the bumpstops. Likely this has parted company (they do!). You can effect a repair with a coat hanger or similar to get you going. If not hard fault, might sort itself, a battery reset wouldn't hurt or use the icarSoft to clear all faults.
8th Mar 2018 8:20pm |
Just had a look the sensor rod is no longer attached to the plastic arm.
8th Mar 2018 8:42pm |
W14shp Member Since: 12 Dec 2017 Location: North Yorkshire Posts: 28 |
Just had similar when trying to calibrate my height sensors. Didn't know what I was.doing basically. |
11th Mar 2018 7:34am |
@RR1994
11th Mar 2018 12:54pm |
RR1994 Member Since: 10 Mar 2018 Location: london Posts: 8 |
Joe, Thanks (i rebuilt compressor new ring - desce replaced- motor runs when i cross connect at relay) but not with relay In
13th Mar 2018 11:20am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
senior moment |
13th Mar 2018 3:53pm |
@ RR1994
13th Mar 2018 4:43pm |
Joe,
14th Mar 2018 12:17pm |
ECU is located passenger side, behind the lower fascia finisher (equivalent to where the OBDII connector is on the drivers side)
14th Mar 2018 3:51pm |
joe,
14th Mar 2018 4:41pm |
Test / Replace relay ? (usually one comes in the box with a new compressor)
14th Mar 2018 5:16pm |
Joe
14th Mar 2018 6:46pm |
http://www.fullfatrr.com/forum/topic27157.html
14th Mar 2018 9:13pm |
