![]() | Home > Technical (L322) > 2011 fuel gauge |
Sarchopperman Member Since: 11 Aug 2017 Location: Aberdeenshire Posts: 33 ![]() ![]() ![]() |
I have had the same problem ....... intermitantly the fuel gauge reads zero. This is a real issue as the ECU thinks the car is running out of fuel. First it will start to judder increasing in frequency followed by the engine shutting down. The car will restart but will repeat this cycle.
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 750 ![]() ![]() |
Thanks for that - looks like exactly the problem I've got, well worth a try before shelling out £500.
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16311 ![]() ![]() ![]() |
I presume you do actually have fuel in it??? |
Unfortunately yes, I’d only just filled it up when it decided to misbehave so getting the pump out will be more of a pain than it needed to be.
You want to get the tank as near to empty as you can. I did the job with the tank half full and it was manageable. |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
For clarity; is that the right cover when in the car, looking towards the back ? ie the passenger side?
Sitting in the driver seat looking forward, the right side of the car is on your right. To remove the tank internals you will need to remove both covers. The fuel senders are held in place by spring location devices and are easily removed. The fuel pump is on the right side. There are two connector plugs to replace as there are two sets of blue and black wires. I do suggest you remove the internal and put in a tray to catch any diesel fuel leakage. I also suggest that you solder your inline splices. These are small diameter wires and not easy to crimp. |
Thanks to Sarchopperman
tj2k Member Since: 10 Dec 2017 Location: Shropshire Posts: 34 ![]() ![]() ![]() |
I'll chip-in with my issue:
I don’t think it would be possible to do the fix either crimp or solder without removing the pump from the tank, access to the offending connections through the tank access holes is a none starter.
Yes that does - thanks very much & I'll take the advice on the two bars (which look like grab-handles!) too.
Please post some pictures on this thread when you do the job.
Going by the service history (it's still full main dealer), it's due a service this month and so I've asked my local (Hatfields in Shrewsbury) for a standard service quote (I'm expecting circa £500!) plus the cost of what they'll do this job for.
Cass’s tip about the seat bars;
