Home > LPG > LPG system causing a petrol leak?
SoggyBottoms
United Kingdom 2007 Range Rover Vogue Supercharged Zambezi Silver
sacrilege though it may be I used my car to block my driveway for a few weeks whilst I awaited new gates to be built.
took her out for a spin and a refuel yesterday now the gates are sorted
when I flicked the fuel over to LPG I noticed a smell of petrol immediately so pulled over
petrol was leaking from a point inboard in front of the nearside rear wheel
on a hunch I switched the fuel system back to petrol and the leak stopped
obvs I'll get the car booked in to see Hiltons but wondered in anyone had any ideas?
Post #459440 3rd Dec 2017 2:02pm
steptoe
Strange, it shouldn't make any difference as petrol continues be pumped through the fuel system the normal way even when using LPG.
Post #459460 3rd Dec 2017 5:10pm
dingg1
my monies on it running slightly higher pressure to the petrol fuel rail when on lpg and you have a pinhole leak thats only evident when the petrol system is running when not on demand , once you go back to petrol the fuel rail pressure drops by just enough to stem the leak
should be easy to find the leak anyway.
Post #459531 4th Dec 2017 9:27am
Danwilderspin
Some fitter run a line back to the tank so if on gas it will pump a loop and pressure is as expected, I had this on my m6 and on petrol it leaked. Turned out it was a bad fitting on the petrol to engine side of the valve Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #472338 12th Mar 2018 11:00pm
