Home > Technical (L322) > P2264 - Water in Fuel Sensor Circuit - 2011 4.4 TDV8
Page 1 of 3 123>
OtleyDominic
In relation to a separate thread, I have this message appearing on the codes but not on the TFT, and I think it is causing restricted performance. It recently had a new fuel filter and housing, but the issue persists. The fault was also on when we tested it with the sensor disconnected from the fuel filter which seems to indicate it is not the fuel filter housing? Help very welcomed.
Post #469357 19th Feb 2018 5:49pm
Kinger
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
**BUMP**
I have the same code on my 4.4 TDV8 and its the only code i can find, i get a very intermittant 'Restricted Performance' message with no ill effect on the cars driving at all, i revs right round is smooth and goes like a rocket.
sometimes the light is on...others itll go days without coming on..any ideas anyone?
Mike
Post #469777 23rd Feb 2018 1:52pm
OtleyDominic
Fingers crossed someone knows the answer!
Post #469797 23rd Feb 2018 4:52pm
Baltic Blue
I fear you are going to have to remove the fuel filter again and replace the sensor.
Unless of course you have filled up with water contaminated diesel ? G reg 2.5VM Vogue Portofino red 1991- 1999
Post #469804 23rd Feb 2018 5:36pm
Kinger
I judt found the sensor, dangling down in the engine bay, looks like it wasnt put back on
Securely after its service and filter change recently
Fingers crossed, i switched the car on after reconnection and the RP warning was off
Cheers
Thanks for your resonses
Mike
Post #469827 23rd Feb 2018 7:47pm
OtleyDominic
Mine is all attached and still throwing the fault Sad
Post #469885 24th Feb 2018 11:41am
nino_nino
Dominic, try unplugging cable and cleaning connector with el. cleaner and spraying some WD40, it cant hurt.
Post #469892 24th Feb 2018 1:54pm
OtleyDominic
Thank you, will give it a try.
Post #469899 24th Feb 2018 4:01pm
OtleyDominic
JAS kindly worked on it today and it looked like the water fault was down to a fault fuel filter housing and sensor! All fixed now, happy days Smile
Post #470440 28th Feb 2018 9:23pm
Kinger
Mine just threw this message up again...RP on the dash but nothing happens to the car...
I drained some fuel out but it wasnt contaminated
I did change the filter to see if that would help, i have tried to find a chaffed wire but everything looks good
I have cleaned all the connections with electrical contact cleaner...
Starting to think the sensor must be bad now....for some reason you cant just buy the sensor, only the whole housing with the wires attached
Any ideas ?
Post #471671 8th Mar 2018 4:47pm
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
Had similar at Christmas after I hit a bit of flooded road at speed - no restricted performance message, went away of its own accord.
Post #471698 8th Mar 2018 7:43pm
OtleyDominic
Unnecessary quote removed
I believe it is a whole fuel filter housing unit as the sensor does not come separately
Post #471702 8th Mar 2018 7:55pm
Kinger
After all my messing around with the water in fuel sensor wires and swapping the filters the RP message was coming up almost permanently so i spoke to Maltings about the Sensor wiring they sell for the TDV8 3.6, they were pretty certain it would be ok for my car and for the sake of a tenner inc delivery i ordered one late on Thursday afternoon, it arrived at 7:00 am on Friday!!! so a big shout out to them for excellent customer service.
I decided i would just swap out the wiring harness first and leave the in filter sensor to later if needed.
The only difference in the 2 looms was the length on the wire from the junction box to the main loom plug was much longer than my existing one, obviously not really a problem, the length of the sensor wire from the junction box to the in fuel sensor was the same, 5 minute job to do after collecting the right size spanners to use
Turned the car on and RP message is gone, have run round in it today trying to provoke it to coming back on and its still off
So....Fingers crossed, it looks like its fixed, if not i still have a new in filter sensor to go one step further...but if anyone with a 4.4 is thinking they have to spend £250 to buy a new filter housing to get the wiring for their car because it isnt available seperately....give Maltings a call and spend a tenner Very Happy
Cheers
Mike
Post #471954 10th Mar 2018 2:56pm
Gr4h4m
United Kingdom 2010 Range Rover Vogue SE 4.4 V8 Santorini Black
Thanks for the tip I will try them today, as I have the same code and issue.
Post #569783 14th Oct 2020 8:14am
Gr4h4m
The 3.6 tdv8 part turned up today. I will check the connections and install it at the weekend.
Post #570047 16th Oct 2020 5:43pm
Page 1 of 3 123>
