Home > Technical (L322) > Analog Clock time adjust??
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
The analog Clock (in the lower front centre section of the dash below the heater controls ) reads wrong on our 2006 TDv8.
It's about 10 mins difference to the digital display.
There's no obvious manual buttons & the clock settings menu via the main display screen shows the time as indicated by the digital display.
I've searched the vehicle user manual & Google, this & other RR forums, but have found no mention of how to adjust it.
Can anyone enlighten me how it's done?
Thanks in anticipation!
Hope it's not something embarrassingly simple I've missed Laughing Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #471788 9th Mar 2018 11:51am
They should sync - try changing the time & see if they sync up and then change it back again ?
Post #471790 9th Mar 2018 11:55am
zarnd
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Bonatti Grey
You change it from the central screen with the sat nav etc... in it and they should both change. Change the time to something made up and then set it correctly again and see if they sync.
cheers Alex
2018 Skoda Kodiaq vRS
2009 Caterham Supersport Race car
2007 M5 Touring
2005 Range Rover Vogue SE Supercharged
2004 SL55 AMG
Post #471794 9th Mar 2018 1:52pm
Pawl
You're a star & I think that probably does count as embarrassing - I should have tried that previously - lol.
Quite satisfying to see the hands on the analog Clock whiz forwards, then backwards when I adjusted it!
Now all in sync. Paul,
Post #471797 9th Mar 2018 2:08pm
Post #471799 9th Mar 2018 2:44pm
Happydaze
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
My analogue clock doesn't work either (new to me 2007 tdv8 Vogue) even though I've corrected the time on the screen. I suspect the clock itself is broken but before diving into a used replacement I'm wondering if there are any known issues or tricks. I've looked for fuses and read everything I can find to no avail. I've not pulled the panel out as yet but I can't imagine it to be as simple as it not being plugged in!
All and any suggestions appreciated.
Post #607090 22nd Sep 2021 9:16pm
