Home > Technical (L322) > Td6 low pressure rail
Steffan1991
Wales 2004 Range Rover Vogue Td6 Epsom Green
Hi im new to this site so hello. I have always had landrovers but never a range rover. I had this one around Christmas time of my old man, it will start and run fine but won't restart straight away, it needs to be left half hour or so. What my question is, is what should the low pressure rail be before and while cranking over as I'm only getting 101kpa before and 91kpa while turning over. Any help is much appreciated. A d here is a pic
Post #471525 7th Mar 2018 6:15pm
Steffan1991
I just checked the pressure again knowing it would start because I have left it for a while and the pressure is up to 250kps ish but as soon as I turn it off a d try again now it's back to square 1? Second fuel pump maybe??
Post #471564 7th Mar 2018 9:10pm
Stevie_b
Scotland 2002 Range Rover Vogue Td6 Zermatt Silver
From memory 300kpa before it'll inject fuel, it's usually the secondary pump on the side of the tank which causes problems. How much fuel is in the tank and do you see air being purged through the pipe going to the fuel filter when you turn the ignition on?
Hope this helps
Post #471568 7th Mar 2018 9:26pm
Steffan1991
Thanks, there is always around 1/4 of a tank of fuel in it and as for air in it I'm not sure but will definitely check in the morning, so 250kpa is a little low?, i ordered a new secondary pump yesterday so fingers crossed thats the problem.
Post #471581 7th Mar 2018 10:02pm
Steffan1991
For anyone who is interested it was the secondary fuel pump, i also removed the egr at the same time, its a1 again now unroll the next time 😂
Post #472527 13th Mar 2018 10:33pm
