![]() | Home > Maintenance & Mods (L322) > Tight tolerance mode and suspension calibration |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1416 ![]() ![]() |
I'm going to stand corrected I'm sure ... but ...
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3869 ![]() ![]() ![]() |
I mistakenly left mine in tight tolerance mode after I had finished, big mistake compressor was running almost constantly as car tried to keep itself within the tight tolerances. Geoff |
counter of beans Member Since: 18 Aug 2017 Location: Hampshire Posts: 182 ![]() ![]() ![]() |
Cheezels, I put the car in tight tolerance mode when I calibrated my suspension, which I think the GAP manual advises to do. Just remember to change it back afterwards to normal.
Have never used tight tolerance mode... .
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 862 ![]() ![]() ![]() |
nor have I - but I will be getting Kwik Fit to do my wheel alignment on their Hunter Hawkeye laser system in the New Year, and have found out that it's pretty easy to do with my IID tool
Height calibration isn't required if replacing the suspension struts, geometry alignment is though. Personally I have always used tight tolerance mode when carrying out any geometry adjustments, if it was my own vehicle, I'd check height calibration before & after geometry adjustment. If it was a customer vehicle, I'd drop it into tight tolerance for the geometry but only do the height calibration if requested / paid for. The reason for checking the height calibration is that during repair operations, the suspension (and height sensors) are manipulated in directions and positions that wouldn't happen on (or off) road, it makes sense to me to check the calibration given the number of moving parts, linkages etc. that all have manufacturing tolerance in them. Once the vehicle has settled under it's own weight, the likelihood of variances from the previous calibration are (to me) high enough to justify the time taken to check and reset. |
Tight tolerance mode is not required nor is it advised in the GAP IID calibration procedures. Worthwhile during wheel alignment as is doing a height calibration before having a wheel alignment done. Also make sure all the adjusters are not seized and that there is no play in any of the bushes or bearings. 2012 TDV8 Vogue (L322) |
