Home > Technical (L322) > Suspension Calibration
Rich_Allen
Quick question for the suspension gurus...
I have been running mine a few inches higher in standard mode and have just recalibrated to normal as one of the rears was about 10 mm lower than the rest
I have noticed the most you can set a sensor at on the IID Tool is 250. 3 of my sensors at normal height are around the 190-200 mark and one is at 249, probably explaining why it didn't raise to the same height as the others as it was already supposedly at its max...
Any solutions to this or reasons? Can you reset the sensor so it does not think it is at its max or is it Censored ?
Hope this makes sense...
Cheers 2008 TDV8 Vogue SE
2002 TD6 Vogue
2002 Defender 90 TD5
2002 Range Rover P38 Autobiography
2002 Range Rover P38 Westminster
Just a sucker for big bills!!!
Post #471308 6th Mar 2018 9:07am
Have you checked the sensor linkages, one might have come off. There is nothing that can't be fixed with a hammer😜😜
Post #471386 6th Mar 2018 7:29pm
